Liquidnight1026
Dec 19, 2016Aspirant
N300 C3000 troubleshoot red power LED
Good morning,
I am not currently home with the router but I'm hoping my question is general enough. When I first got this router, I had this same issue. My power LED is red, but all of the other lights are solid green. After some flubbing, (read: I'm not sure what I did) I got it to work.
Last night the same issue occured, but no amount of flubbing is changing anything. I tried to unplug it, leave it unplugged for a bit, plug it back in, push the on-off button, and the factory reset button on the bottom but nothing ever changes. I like to think I'm fairly tech savvy, so I took to Google for help and couldn't find anything specific like this. I appreciate any advice and I can get more information from someone home if specifics are needed. Thank you.
- Retired_Member
Red power LED usually means hardware failure, the manual for this device is a JOKE It doesn't address a red or amber power LED.
Bottom line if less than a year old contact support via MyNetgear...support....replace my defective device.....over a year replace it.
- Liquidnight1026Aspirant
Hey searay,
I'll have to say that I agree... although I had high hopes for a 100 page manual.
I bought this item refurbished off ebay, and I have contacted the seller.
I called NetGear tech support this morning. The guy told me to update the firmware from NetGear's page (which I am unsure if I will be able to do seeing as how I cannot connect to the internet), or I could have one of their techs do it for me for a price. Which I cannot even image what that will cost me.
I just don't want to pay Time Warner Cable that extra $10 a month anymore! This is what I get for being cheap, I suppose ;)
- Retired_Member
Buying a used router is like buy used underwear..........
