robb-bob
Feb 22, 2020Aspirant
N300 C3000 Will the C3000 reset itself after a power outage? I am away from home several days often
- Feb 22, 2020
Yes, it did reboot and working properly.
Feb 22, 2020Guru - Experienced User
theoretically it should. I've had mine reboot normally after power failures.
But if you're getting that many power failures, I'd look into a backup power supply. they're fairly inexpensive and are great to protect expensive electronics. After loosing 1 router, I invested in a backup power supply. nothing like loosing a several hundred dollar router to make a backup power supply look cheap.
- robb-bobFeb 22, 2020Aspirant
Thanks for the reply. I just got off the phone with a Netgear tec who told me that the C3000 will not reboot on its own after power is restored. He recommended a UPS. Now I am confused.
