ddalton's avatar
ddalton
N300 modem/router model C3000 with increasing frequency of loss of internet and/or wifi connections
I've had this modem/router for a little over 2 years. The frequency of losing internet and/or wifi connections seems to be increasing. The problem is resolved fairly easily by rebooting the router. M...
  • DarrenM's avatar
    DarrenM
    Aug 16, 2017
    timeouts are typically a issue with the cable lines I suggest having your ISP send a tech out to check the lines.
    DarrenM
