dargpat
May 31, 2016Follower
N450 - CG3000DV2 - No Content Filtering in software V1.03.03?
Did netgear remove content filtering from the N450 or did my ISP.
I noticed online in netgear support that v 1.02.10 supported content filtering and there is documentation on how to activate it. I remember with my old NG router this could be done. Now that I need to activate it on my N450, the option/category is not available on the menu on v .1.03.03.
I also noticed that you can not update the firmware yourself as I could before on my older NG routers and said it could only be done by the ISP through the inet. My ISP is COX.
- DarrenMSr. NETGEAR Moderator
Hello dargpat
according to the article it is only available in v1.02.10 I would have to check why it was taken out if Netgear did it.
DarrenM
- Stalemate1Aspirant
Yes, I also need "Content Filtering". The manual says it is available but it not! Very frustrating to purchase something for a specific reason, then it does not do what it is advertised to do - "Content Filtering".
Thanks.
