DRAKEKSE
May 08, 2016Initiate
N450 - Crashes/reboots itself every couple minutes
I have been running tthe N450 for a little over 3 months now with little to no problems. A couple days ago I noticed that I was randomly having connection issues. Upon further inspection I noticed t...
VE6CGX
May 08, 2016Master
I asked and suggested something, you just tslk away not responding to what I suggested. Very dificult to trouble-shoot. I am not
on your side whereever you are. UInless some good info. is provided there is nothing much any one can do. You just keep saying
it does not work well. Sorry. I am asking again. Is Xfinity modem is jut modem or is it modem/router combo? How did you set up
your own router? Are you using Genie?
DRAKEKSE
VE6CGX thanks for the sugestions. Sorrry I'm just now responding, it has been a busy mothers day! The Modem is not hot to the touch. The Modem is mine and my ISP is COX. I will try running the router with the cables re. I will have to look for an alternate power cable as well. Thanks!
Below are 2 recuring log events that I'm getting:
| Time Not Established | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:84:8a:40;CMTS-MAC=70:ca:9b:a7:97:74;CM-QOS=1.0;CM-VER=3.0; |
| Sun May 08 20:51:18 2016 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=2c:30:33:84:8a:40;CMTS-MAC=70:ca:9b:a7:97:74;CM-QOS=1.1;CM-VER=3.0; |
- DarrenMMay 11, 2016Sr. NETGEAR Moderator
Hello Drakekse
If you are getting alot of T3 and T4 timeouts this may be a issue with the cable lines you may want to have your ISP check things out. Here is a link that explains the timeouts.
http://volpefirm.com/docsis_timout_descriptions/
DarrenM
- AthaxtoJul 19, 2016Aspirant
Hello DRAKEKSE - I too have COX as my ISP and I'm having similiar crash/reboot issues as you were. Mine seem to happen most often when I use a different device that accesses my router (iPad, laptop, AppleTv, etc). I'm a bit of a newb when it comes to troubleshooting. How did you find the log events that you shared below? I have Netgear Genie, but I can't seem to find where to access the logs that provide this data/info so that I can provide it to COX. I've called COX and they say it's an amp issue, Any assistance would be greatly appreciated.
