gm031555's avatar
gm031555
Follower
Jul 09, 2016
N450 and Netgear Genie
Is Netgear Genie compatible with the N450 and is Netgear Genie now compatible with WIN 10 ?
Thanks
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello gm031555
    No genie will not support the N450 if its on the smart wizard when you log into it and yes genie will work on windows 10
    DarrenM
