Suvadip01's avatar
Suvadip01
Follower
Dec 01, 2016
N450 CG3000Dv2 Bridge Connection
I need to connect the N450 to another Powerful Router
1 Reply
  • It should be the NAT setting under the advanced side. Click on advanced at the top of the screen, then advanced setup on the left, and NAT mode. If you need to get back into the modem after this has been done, you need to factory restart your modem
