mopar_dave
Dec 26, 2018Tutor
N450 CG3000Dv2 Can't login to router settings
I have recently gone back to cable internet after about 4 years. Pulled out my N450 and hooked it up. Can't remember signin for router settings so have hit the reset button several times, the route...
antinode
Dec 26, 2018Guru
> Pressed for about 12 seconds [...]
That all sounds good, except fot the part where it doesn't seem to
reset the "admin" password to "password".
> [...] Any other ways to reset or change settings? [...]
Because it's a DOCSIS cable-TV thing, there may be little you can do
to influence the firmware directly. You might ask your ISP if they can
do anything useful from their side.
mopar_dave
Dec 26, 2018Tutor
30-30-30worked like a charm. Thanks
