McDoug
Sep 25, 2017Guide
N450 CG3000Dv2 Unable to access USB ports
This is a repost as I have not been able to resolve this and Netgear refuses to help. I installed the N450 Cable Modem in-order to have access to an "external" USB hard drive to serve as a Back...
bugmenot123123
Sep 28, 2017Initiate
Happy I found this thread and learned its not just me with this problem. Been going crazy trying to fix this: trying a bunch of flash drives which all worked everywhere else, unplugging the router, reseting it using the insanely tiny button on the back BUT nothing worked. And now google leads me here. Good to learn its not only me but very bad to learn netgear won't do anything to help. At least mine is within the return window so back it goes. Will buy a different brand instead and post a review of this one to warn others. Good luck to you guys that are stuck with yours!!!
McDoug
Sep 28, 2017Guide
Mine is within the return/replace window also but so far Netgear has refused to respond to my online request for warranty replacement,
