McDoug
Sep 25, 2017Guide
N450 CG3000Dv2 Unable to access USB ports
This is a repost as I have not been able to resolve this and Netgear refuses to help. I installed the N450 Cable Modem in-order to have access to an "external" USB hard drive to serve as a Back...
ErnestTheGreat
Jan 02, 2018NETGEAR Employee Retired
I am not sure if you guys are aware but Microsoft dropped support for SMBv1 in latest Win 10 Fall Creators Update so if your ReadySHARE implantation is using SMBv1 you will have issues with accessing your drives. Netgear has a FW update coming for the N450 that will fix this issue. Your ISP will push the update when it became available as each cable FW has to be certified/approved by ISP before the ISP will push it out. This issue is will occur on all devices that do not have SMBv2/SMBv3 support not just Netgear N450 device.
ahalmay
Jan 02, 2018Aspirant
I JUST found that out. I would have been nice for registered users of the products to have been notified. There is a workaround, supposedly. I have a US Robotics adapter on order so I can use an ethernet to USB to effect an NAS
- McDougJan 02, 2018Guide
This is the first I've heard of this and believe me I am glad and yes it would have been nice (and good business practice) for Netgear to let us know ... but that would have meant acknowledging to the public that they knew about this and still refused to talk to the registered users.
