Andre3's avatar
Andre3
Follower
Nov 10, 2016
N450 CG3000Dv2
How does one transition this device to serve as a bridge to a more powerful WIFI router?
  • DarrenM's avatar
    Nov 14, 2016
    Hello Andre3
    This modem has no True bridge mode but you could click on the LAN Ip settings and switch the DHCP to no and disable the wireless SSID broadcast of the modem it may work for you but may not be the best solution.
    DarrenM
