BeeVee
Dec 31, 2015Follower
N450 disconnects every hour
Hello, Been having issues with my N450. For the past month its been disconnecting me from my online gaming about every hour. Doesn't matter what game I play, it resets the connection. The console...
jkerplay
Jan 09, 2016Aspirant
I have the same model and mine has the same issue. Mine is hardwired. Any idea why it disconnects?
DarrenM
Jan 12, 2016Sr. NETGEAR Moderator
jkerplay
I would check all your connections make sure its not a bad cord also if you have a cable splitter I would check that may even want to remove it and see if the connection improves. The last thing you could try is a factory reset. If all that fails you may want to contact netgear phone support if the modem is still under warranty.
DarrenM
