dm99
Jan 26, 2016Aspirant
N450 LAN connection problem via a switch
I replaced my Time Warner Ubee router with a Netgear N450. I have 2 desktops and a TV and PS3 in my basement connected to a Netgear GS108 gigabit 8 port switch. Everything worked fine until I swapped...
- Jan 27, 2016
Problem solved. I brought the Win 7 PC upstairs and connected it directly to the router. The PC immediately recognized and connected to my Home network. Then in order to eliminate possible issues with the switch itself or cabling, I brought the switch upstairs and connected it between the router and the Win 7 PC. Same results as above - connected to Home Network and Internet. Took everything back downstairs and voila - both PC's are now connected successfully to the Home network and the internet using DHCP automatically. Not sure why this worked. I went through this process merely to diagnose possible hardware issues.
Mars Mug
Jan 27, 2016Virtuoso
Do all the Ethernet ports at the switch and router illuminate as expected? Do devices that are attached to the switch ‘see’ each other when you set them with static IP addresses? Are you sure the switch connection back to the router is connected to a router LAN port and not the WAN (Internet) port? Is the modem connected to the WAN port?
- dm99Jan 27, 2016Aspirant
