baylessm
Mar 06, 2021Aspirant
N450 No Internet access but shows connected
WIFI shows connected, but internet isn't accessable. Spoke with our internet provider, they say all of their systems are functioning properly. They suggested reaching out to NetGear. I have uplugged,...
Mar 06, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed with a wired router or laptop?
baylessm
I reset the router with a laptop attached via wire. The issue continues. The internet company also reset will it was connected.
- FURRYe38Mar 06, 2021Guru - Experienced User
Possible the modem is bad. I would try another modem or newer modem and see. Either a modem only unit with a external wifi router or a all in one combo unit.
