baylessm
Mar 06, 2021Aspirant
N450 No Internet access but shows connected
WIFI shows connected, but internet isn't accessable. Spoke with our internet provider, they say all of their systems are functioning properly. They suggested reaching out to NetGear. I have uplugged,...
Mar 08, 2021Guru - Experienced User
Is it this model?
N450 | Product | Support | NETGEAR
do you have a screen snip of the cable connections page and the modem event logs? those help us to check signals. The ISP's are great at saying "the signals fine" it must be your device.
