lawsonde
Oct 02, 2015Follower
N450 trouble after self test
CG3000Dv2 the red lights were flashing signalling a self test, and afterwards, it will not broadcast wifi signal. The wifi light is on, everything appears normal, but I cannot find the network on any...
DarrenM
Oct 05, 2015Sr. NETGEAR Moderator
Hello Lawsonde
go into the router and make sure the SSID is being broadcasted under Advanced then wireless settings if ti is and still can see the Wifi do a factory reset. see if that works.
DarrenM
