pranit22's avatar
pranit22
Follower
Aug 05, 2015
N450 WiFi Cable Modem Router Model No: N450/CG3000Dv2 Wifi problem
Hello,
My wifi modem router was working fine for more than a year now but suddenly the wifi stopped working. I can see the SSID in the available networks list but all my devices say "Connection timed out" while attempting to connect to wifi. I have also tried resetting to factory settings, still no luck. Please help.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello pranitt22
    Have you tried to connect to the wifi with out any security enabled just to rule out that being a issue. If you have tried this and tried to factory reset then i would say something has failed on the modem/router I would check to see if the device is still under warranty and contact support if it is.
    DarrenM
