Vivienne
Sep 05, 2015Follower
N450 WiFi keeps disconnecting
Hello, So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the...
jacwa01
Sep 24, 2015Aspirant
I too am having the same problem: my laptop (Windows 8.1), and my daughter's Macbook and Apple TV experience loss of access to our home network at various times of day. I am forced to turn Wireless off/on, forget the network, and/or run troubleshooting diagnostics.
NETGEAR support had me change Channel from 1 to 11, and things seemed to work for a while, but now the disconnects are back. I have gone to the admin site and checked the power levels and signal-to-noise ratio for upstream/downstream power and they appear to be well within spec.
Anybody have any new ideas??
amitshah28
Nov 11, 2015Aspirant
I have the same issue...on the hardwire the N450 works super fast but on wireless its super slow ..had comacast guys check for 3 hrs all connection , software etc..from their end the signal is good ..looks like an issue to n450 for wireless connection on comcast
