Vivienne
Sep 05, 2015Follower
N450 WiFi keeps disconnecting
Hello, So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the...
amitshah28
Nov 11, 2015Aspirant
I have the same issue...on the hardwire the N450 works super fast but on wireless its super slow ..had comacast guys check for 3 hrs all connection , software etc..from their end the signal is good ..looks like an issue to n450 for wireless connection on comcast
DexterJB
Nov 24, 2015NETGEAR Moderator
Hi amitshah28,
1. Does the issue happen on all of your devices?
2. Have you tried changing the wireless channel?
3. Does the issue happen whether the devices are close or far from the N450?
Dexter
Community Team
