Vivienne
Sep 06, 2015Follower
N450 WiFi keeps disconnecting
Hello, So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the...
craigwf
Apr 02, 2016Tutor
In case anybody is following this thread because they are having the same issue, I have now gone through Level 2 Support who made changes in the settings to no avail and has subsequently authorized an RMA number to obtain a replacement because they "have identified the hardware issue causing this problem."
croaker69
Apr 10, 2016Initiate
I've been getting the same issue since this update was pushed.
CG3000Dv2 N450
H/W rev: R2.05A2
F/W rev: V3.01.06
However my frequency has been 3-5 times per day all connections are dropped until I force a reset of the wi-fi by making configuration change(I usually just change channels or max speed, apply, and then revert). Router web GUI shows the wi-fi as up the entire time. With 3 family members using iPhones on a shared data plan this has put them over their monthly data limit in two days. I need a fix fast.
I've been using all these same devices for nearly a year prior to the Comcast push that upgraded the f/w to v3 from v1.
- craigwfApr 10, 2016Tutor
It cost me $16.90 to get a replacement gateway shipped along with pre-paid return postage. Netgear sent me a brand new (not a refurb) gateway of the same model as the defective one. Thus far (3 days) the wifi has been rock steady 24/7. I suspect a certain percentage of that model had a defective part. Hopefully the replacement is not one of them.
- craigwfApr 17, 2016Tutor
And on the 8th day, the brand new CG3000DV2 disconnected all wifi devices and would not allow them to reconnect until I unplugged and then re-plugged the power to the gateway. What is causing this behavior? Could this be the firmware Comcast has pushed to me, V3.01.06? I am very disappointed. I thought Netgear was known for reliability.
- craigwfApr 22, 2016Tutor
After another three days from the last post, again got disconnected from all wifi devices and was unable to reconnect until a hard reboot. Called Netgear Tech Support who was quick to blame Comcast saying that if the problem came from both the original purchase and from the "tested" replacement they sent (probably a return that had the same problem but seemed OK when they tested it for 2 minutes), then it must be a problem with the ISP. They are, however, shipping me a new replacement unit. We'll see how that works out.
- craigwfApr 26, 2016Tutor
I called Comcast and some lady in India told me she would "synchronize" my gateway and that "this this will fix the problem." After she did it, nothing changed on the gateway; it didn't reboot or have any changed settings. Four days later I awoke to find all wifi devices disconnected and unable to reconnect until I did a hard reboot of the gateway. :smileysad:
