Vivienne
Sep 06, 2015Follower
N450 WiFi keeps disconnecting
Hello, So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the...
craigwf
Apr 22, 2016Tutor
After another three days from the last post, again got disconnected from all wifi devices and was unable to reconnect until a hard reboot. Called Netgear Tech Support who was quick to blame Comcast saying that if the problem came from both the original purchase and from the "tested" replacement they sent (probably a return that had the same problem but seemed OK when they tested it for 2 minutes), then it must be a problem with the ISP. They are, however, shipping me a new replacement unit. We'll see how that works out.
craigwf
Apr 26, 2016Tutor
I called Comcast and some lady in India told me she would "synchronize" my gateway and that "this this will fix the problem." After she did it, nothing changed on the gateway; it didn't reboot or have any changed settings. Four days later I awoke to find all wifi devices disconnected and unable to reconnect until I did a hard reboot of the gateway. :smileysad:
