Vivienne
Sep 05, 2015Follower
N450 WiFi keeps disconnecting
Hello, So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the...
bakingsoda
Oct 31, 2016Aspirant
What is the second router you use to test with?
I'm also having the same issue with my N450 with Time Warner. Only started noticing the issue recently. On TWC's site (Should I Lease or Buy a Modem page -> Download speeds up to 100Mbps section), the N450 is grayed out and listed as an "Internet Modem Only". TWC is probably trying to force us to an upgrade and make it seem like there is an issue with our hardware. Obviously this is not just an "Internet Modem Only".
https://www.timewarnercable.com/en/support/internet/topics/lease-or-buy-modem.html
rmctodd
Hi:
I used a Linksys WRT54G router which is an old router.
I should add that this one was working well for a year and I suspect that a firmware upgrade ruined it. This is not just a modem.
