Vivienne
Sep 05, 2015Follower
N450 WiFi keeps disconnecting
Hello, So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the...
tomlyu
Nov 02, 2016Aspirant
Totally agree with you, we need to make more noise to be heard...
Btw, here is the so called "tier 3" tech support number of TWC: 718-358-0900
One of their excuse was: if we pushed out wrong firmware we should have seen many complaints now...
aniorange
Nov 03, 2016Aspirant
I came here looking for help because I have had the same issue. We have had the N450 just over a year and it worked fine until about a month ago. Then the wireless started becoming a problem. Computers were connected but had no internet and the only solution was to restart the N450. This happeded every few days. The past 3 days, the speed has been horrible. The disconects are getting worse. I see that this is a issue for many others and the blame is being tossed around. I chose Netgear because I have been satisfied with Netgear products in the past, but it looks like it's time to abandon Netagear and look elsewhere. One of my roomates works from home and this just will not do. We need a solution.
