Vivienne
Sep 05, 2015Follower
N450 WiFi keeps disconnecting
Hello, So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the...
bobbye
Nov 03, 2016Star
craigwf - from what I read you're on Comcast,is that correct ?
Also, from other responses about this issue, I understnd that the ISP's have ccess to the firmware source code,
I thought that maybe TWC has some bug, but if this is happening also with Comcast,
then I suspect the bug is in the Netgear code.
I just can't beleive that Netgear has avoided this issue for months, and now that TWC has pushed the faulty vrsion
(althoguh they will not admit it), they also, have to be responsible for fixing this.
THIS IS A NETGEAR FORUM, WHEE IS THE NETGEAR REPRESANTATIVE ????
PLEASE ADVISE AS TO WHAT IS DONE ABOUT THIS SERIOUS ISSUE
aniorange
Nov 03, 2016Aspirant
I neglected to mention I am also a TWC subscriber. I am thinking that perhaps I should pick up a seperate modem and router, that way any firmware upgrades do not impat the wireless protion. I am also thinking of puchasing one that I know they use. Before I moved I rented a Surfboard modem router combo that worked great except for the occasional hiccup. It would occasional drop signal but right itself after a minute. The Netgear has to be unplugged.
