Vivienne
Sep 05, 2015Follower
N450 WiFi keeps disconnecting
Hello, So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the...
invalidation
Nov 03, 2016Guide
I'm also having this problem - it started when TWC Pushed the firmware to v3
Wifi appears to "lock" daily - it gets slow then fails to operate. The v1 firmware worked without issue.
rakstemp
Nov 03, 2016Aspirant
Just adding to the forum, having the same issue...
WHERE ARE THE NETGEAR REPS THERE HAVE BEEN NO ANSWERS!!!
I really feel netgear is just avoiding the issue..
I'm postive there are tons of customer with the same issue that just have not posted to the fourm..
- player1Nov 03, 2016Aspirant
I have the exact same problem! Just made an account so I can reply here.. Ping jumps on all my devices also internet gets slower the longer my router is turned on. Turning it on and off solves all these problems until 1-2 hours later i start noticing it getting slower again. After 1 day I usually cant even use it anymore(250mbps download speed goes down to 1mbps...).
Guess I have to get a new router.
- invalidationNov 04, 2016Guide
player1: test the speeds across the wired switch. If we're having the same problem, chances are you're getting full speed there, even after the wireless completely stops working. Seems to just be the wireless set in the device. May be possible to salvage some part of it buy just disabling the interal AP, and buying a separate wireless device.
