Vivienne
Sep 05, 2015Follower
N450 WiFi keeps disconnecting
Hello, So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the...
bobbye
Nov 04, 2016Star
Has any of the folks here contacted TWC or Netgear and managed to make some progress ?
Also, I see that it is not recommended to buy a device that is both modem and router as the N450,
any one has any advice which modems and routers might be decent replacments (of course not Netgear) ?
invalidation
Nov 04, 2016Guide
Yeah, I think I've learned my lesson on this one. Between TWC / Spectrum and Netgear, I don't expect this to be resolved in any reasonable time -- even if Netgear has a fix, they'll have to convince TWC to implement and push it.
Why the wireless firmware wasn't decoupled from the cable modem in this package is beyond me.
I'll see if I can just disable the wireless on this and buy a separate access point for the wireless. At least the switch and cable modem in this aren't broken (yet).
