Vivienne
Sep 05, 2015Follower
N450 WiFi keeps disconnecting
Hello, So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the...
bobbye
Nov 04, 2016Star
Invalidation - are you saying that if we disable the wifi, the latency issue will not happen ?
Also, has anyone got a phone number to the netgear tech support ?
invalidation
Nov 04, 2016Guide
No, I'm saying, at least on mine, the latency issue is only affecting wifi. Wired is continuing to operate at full speed, even after wifi has fully failed.
I *just* read someone saying otherwise in another thread, so I don't know if this is normal or not.
