Vivienne
Sep 05, 2015Follower
N450 WiFi keeps disconnecting
Hello, So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the...
tonyd22
Nov 26, 2016Tutor
I performed the factory reset as described in the post by bobbye. No issues since doing that 2+ weeks ago
- ScuttlebuttNov 26, 2016Tutor
My N450 is having this same issue. Massive ping spikes once every 1-2 minutes which wont stop until I reset the power. After reseting the power the lag spikes subside for a couple hours then the ping spikes happen again.
The amount of people posting about this same problem prove that this problem is Netgears fault.
I WILL NEVER PURCHASE A NETGEAR PRODUCT AGAIN.
