Vivienne
Sep 05, 2015Follower
N450 WiFi keeps disconnecting
Hello, So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the...
4Legacy
Dec 21, 2016Aspirant
Guess what? Same issue. Every 14-16 packets there is a lag spike during ping tests AND intermittent request timed out issues. The device worked fine for the first six months I had it, but once I received the firmware update it has been nothing but trouble.
I thought I was going crazy until TWC came out on the third try and said it was the modem/router combo.
They replaced it with one of theirs, and lo and behold, the issue disappeared.
Netgear, either fix it the firmware with the ISP or I would like this replaced under the one year warranty. This is ridiculous.
