Vivienne
Sep 05, 2015Follower
N450 WiFi keeps disconnecting
Hello, So I bought my Netgear N450 WiFi cable modem router on April 30, 2015 and in the past month I've been having WiFi connection problems. The internet works just fine, but for some reason the...
TeacherLady
Sep 07, 2015Aspirant
I just hooked mine up, and Comcast shows it's working fine. But it keeps kicking us off wireless. Anyone have a fix for this??
DarrenM
Sep 08, 2015Sr. NETGEAR Moderator
Have you guys tried changing the wireless channel something could be causing interference with the signal such as neighbors routers, home appliances, or cordless phones.
DarrenM
- TeacherLadySep 08, 2015Aspirant
I tried EVERYTHING. I finally got the NetGear tech to throw up his hands and say the unit might be malfunctioning. Took it back to the store this morning, got a different NetGear model, and hooked it up with no problems! :smileyvery-happy:
- amitpshethJan 24, 2017Aspirant
Were you within warranty period? It is 90-day, right?
- johnnyBrandomJan 30, 2017Aspirant
I'm outside of warranty. Factory reset did not correct the issue for me.
