BillJones756
Oct 30, 2016Follower
N450/CG3000Dv2 WiFi drop and Interface Lockup
Last week Time Warner Cable pushed firmware V3.01.06 to my N450 modem/router. Since the update, i can't go more than 24 hours without having to pull the power because WiFi drops ALL devices. After ...
- Nov 21, 2016
I did a factory reset and have not been loosing connection for a few days. In the genie menu there is a place to backup your settings. After the reset you can restore the settings from the file you saved. The only thing it didn't restore was the user and password to access the router. The default is admin for user and password for password. Then you can sign in and change that. Still can't usb port to work.
Skeetwales
Nov 03, 2016Star
I would be happy if it could just be reflashed back to the old firmware. Never had problems before this.
