BillJones756
Oct 30, 2016Follower
N450/CG3000Dv2 WiFi drop and Interface Lockup
Last week Time Warner Cable pushed firmware V3.01.06 to my N450 modem/router. Since the update, i can't go more than 24 hours without having to pull the power because WiFi drops ALL devices. After ...
- Nov 21, 2016
I did a factory reset and have not been loosing connection for a few days. In the genie menu there is a place to backup your settings. After the reset you can restore the settings from the file you saved. The only thing it didn't restore was the user and password to access the router. The default is admin for user and password for password. Then you can sign in and change that. Still can't usb port to work.
llewell
Nov 04, 2016Guide
Did anyone else notice that IPv6 appears to be operating now with the 3.01.06 upgrade? I'm wondering if they intrroduced a bug with the dual stack operation, or worse, if the hardware is just incapable of actually running two IP stacks.
In any case, I'm pretty much doing a soft or hard reboot every day now. I guess it's time to look for a new modem, and it won't be a Netgear. I'm going to update my review on Amazon to warn folks away from this model.
