BillJones756
Oct 30, 2016Follower
N450/CG3000Dv2 WiFi drop and Interface Lockup
Last week Time Warner Cable pushed firmware V3.01.06 to my N450 modem/router. Since the update, i can't go more than 24 hours without having to pull the power because WiFi drops ALL devices. After ...
- Nov 21, 2016
I did a factory reset and have not been loosing connection for a few days. In the genie menu there is a place to backup your settings. After the reset you can restore the settings from the file you saved. The only thing it didn't restore was the user and password to access the router. The default is admin for user and password for password. Then you can sign in and change that. Still can't usb port to work.
MD585
Nov 03, 2016Guide
I'm having the EXACT same issue. The only difference is it was happening BEFORE the upgrade to V3.01.06 2 weeks ago. But then it was just one day a week (throughout the whole day... but still)
Since the upgrade from v1.00.05 to V3.01.06 it happens multiple times a day, everyday.
My Event Logs get filled with this when it happens.
(I've cleared my MAC addresses for privacy)
| 2016-11-03, 08:26:33.0 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:01:00:01:00:01;CM-QOS=1.1;CM-VER=3.0; |
| 2016-11-03, 08:26:32.0 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:01:00:01:00:01;CM-QOS=1.1;CM-VER=3.0; |
| 2016-11-03, 04:36:15.0 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:01:00:01:00:01;CM-QOS=1.1;CM-VER=3.0; |
| 2016-11-03, 03:13:06.0 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:01:00:01:00:01;CM-QOS=1.1;CM-VER=3.0; |
| Time Not Established | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:01:00:01:00:01;CM-QOS=1.0;CM-VER=3.0; |
| Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
| Time Not Established | Notice (6) | WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INIT |
I've talked to some corporate DNS/DHCP/Router folks I work with and they said "Check to see if you're NTP Time Server setting is messed up..."
Well, guess what? In V1.00.05 You could set the NTP Service, and in V3.01.06 you can't!
GinjaWesten
Nov 04, 2016Star
That missing BP line and the Timeout error looks like a borked preamble or announce line in the code.
