BillJones756
Oct 30, 2016Follower
N450/CG3000Dv2 WiFi drop and Interface Lockup
Last week Time Warner Cable pushed firmware V3.01.06 to my N450 modem/router. Since the update, i can't go more than 24 hours without having to pull the power because WiFi drops ALL devices. After ...
- Nov 21, 2016
I did a factory reset and have not been loosing connection for a few days. In the genie menu there is a place to backup your settings. After the reset you can restore the settings from the file you saved. The only thing it didn't restore was the user and password to access the router. The default is admin for user and password for password. Then you can sign in and change that. Still can't usb port to work.
GinjaWesten
Nov 04, 2016Star
After being dumped to the menu in Destiny again not ten minute ago, I finally got fed up. I have filed a complaint with the FCC against Netgear and TWC. What really amped it up for me is when I saw the response on here that Netgear wanted to charge one of you $159 dollars to fix a problem THEY CREATED!!
- SkeetwalesNov 05, 2016Star
Just found this on another forum.
going to try it
https://community.netgear.com/t5/Cable-Modems-Routers/Cg3000dv2-is-dropping-wifi/td-p/1157621
- GinjaWestenNov 05, 2016Star
Tried that reset for now, but I don't know if it will *fully* solve the issue - I still believe there are faults in the latest firmware.
- SkeetwalesNov 07, 2016Star
35 hrs after factory reset, had to power cycle to restore wireless. Wired still worked.
Must be that isnt the fix. Firmware is wierd.
- llewellNov 05, 2016Guide
So the "fix" is to reset to factory defaults. So what then? Are they putting their settings back or just running with whatever the defaults are? That won't work for a lot of folks, me included.
Just the default settings for the installed firmware - I'm pretty sure it won't really fix the issue, just lessen the impact for a short time (it's basically a hard refresh for the cache, once it gets loaded up again by the borked firmware the issues will return).
