BillJones756
Oct 30, 2016Follower
N450/CG3000Dv2 WiFi drop and Interface Lockup
Last week Time Warner Cable pushed firmware V3.01.06 to my N450 modem/router. Since the update, i can't go more than 24 hours without having to pull the power because WiFi drops ALL devices. After ...
- Nov 21, 2016
I did a factory reset and have not been loosing connection for a few days. In the genie menu there is a place to backup your settings. After the reset you can restore the settings from the file you saved. The only thing it didn't restore was the user and password to access the router. The default is admin for user and password for password. Then you can sign in and change that. Still can't usb port to work.
rebmark
Nov 21, 2016Aspirant
Thank you Skeetwales. Where do I find that "Genie" menu? Is there an application that goes with the modem that I've not found?
Skeetwales
Nov 21, 2016Star
To get to the Genie menu You log into the router like you did before.
On a browser 192.168.0.1
The Genie menu is just the new firmware router interface.
I liked the old one better. Never had problems before.
- rebmarkNov 21, 2016Aspirant
Please forgive the ignorance of this "Aspirant". When I enter "192.168.0.1" in my browser I receive an alert asking for my User name and Password. A hint as to which of my hundreds of user names and passwords would help.
Thank you for all the guidance so far.
- SkeetwalesNov 22, 2016Star
The genie is just the new router interface, due to the firmware update.
If you had a user name and password before the firmware update,
to get into the old router, use that.
if you never set one up.
Default User name is admin
Default Password is password- SkeetwalesNov 22, 2016Star
For Rebmark
Hard reset
1.Please Remove the co-axial cable from the modem and turn off the modem and once again connect the co-axial cable back to the modem and check please.
Please follow the below steps to Hard reset the modem:
1.Please flip your device and locate the Restore factory settings red pin hole.
2.Make use of a paper clip or small pin and hold it down for 30 seconds when the device is switched on.
3.When you perform the Reset process, the power light would start to flash
4.please do reset when the device is powered on.Router login after, hard reset, check out this article
