BillJones756
Oct 30, 2016Follower
N450/CG3000Dv2 WiFi drop and Interface Lockup
Last week Time Warner Cable pushed firmware V3.01.06 to my N450 modem/router. Since the update, i can't go more than 24 hours without having to pull the power because WiFi drops ALL devices. After ...
- Nov 21, 2016
I did a factory reset and have not been loosing connection for a few days. In the genie menu there is a place to backup your settings. After the reset you can restore the settings from the file you saved. The only thing it didn't restore was the user and password to access the router. The default is admin for user and password for password. Then you can sign in and change that. Still can't usb port to work.
Skeetwales
Dec 26, 2016Star
Did you try the factory reset? Seems to be needed after firmware update.
1.Remove the co-axial cable from the modem and turn off the modem and once again connect the co-axial cable back to the modem and check please.
Please follow the below steps to Hard reset the modem:
1.Please flip your device and locate the Restore factory settings red pin hole.
2.Make use of a paper clip or small pin and hold it down for 30 seconds when the device is switched on.
3.When you perform the Reset process, the power light would start to flash
4.please do reset when the device is powered on.
Tamino
Dec 27, 2016Aspirant
Yes. Thanks to all the information I read about here, I did the factory reset. It seems working. Has been three days, and it has not dropped. I'm keepin my fingers crossed. The speed is still kinda slow though, am comtemplating switching to Spectrum modem, but don't really want to pay the $10 lease fee. But with technology changing so fast, maybe it's a good idea to lease than own.
