scomp23
Jan 31, 2017Aspirant
N600- 2.4 GHz band completely nonfunctional, 5 GHz works fine
I bought this unit in March of 2015. About two months ago, my devices would fail to connect to the typical 2.4GHz band. All of my devices connected just fine to the 5GHz band, which is still the case...
DarrenM
Feb 02, 2017Sr. NETGEAR Moderator
Hello scomp23
This could be a issue with the 2.4ghz band you may try to lower the speed under the mode option in the wireless settings and see if that correct anything. If you do believe it failed you may want to contact support if the modem is under warranty.
DarrenM
scomp23
Feb 02, 2017Aspirant
Thanks Darren- I appreciate the info. Is it not somewhat odd that this occured 20 months after I purchsed the unit, when the 2.4GHz band worked perfectly prior to that?
