Retired_Member
Oct 08, 2020N600-C3700 ethernet does not work WIFI does
My ehternet conenciton suddenly stopped working. i am still able to access internet using the WIFI but using a LAN cable. it used to work before. i have already tried power cycle twice without succes...
Oct 08, 2020Guru - Experienced User
Try swapping LAN ports.
Try swapping LAN cables.
Happens with all wired devices?
Try a factory reset and setup from scratch...
Retired_Member
Oct 08, 2020thanks.
couple good things i havent tried yet.
i only have one device conneted via LAN.
