Rainer91
Jan 05, 2022Tutor
N600 C3700 flashing 3 lights
My router does this every time we lose power. The routers power light is green and the three lights under the power light continually flash in unison. In the past the problem corrects itself after a f...
Rainer91
Jan 06, 2022Tutor
Unfortunately I do not have a pc with an Ethernet port… I did call Comcast and they said the signal is good but they are unable to communicate with the router/modem. I have checked in the past for any splitters and eliminated one. I’ve tried unplugging for a while and tried power off and on with no results. Thanks for the advise! If you have any other ideas I’m all ears!
Jan 06, 2022Guru - Experienced User
They make these USB to ethernet adapters that help connect those PCs or laptops with out ethernet ports to connect to wired devices. I recommend if you can get one of these, would be helpful.
And after doing a reset on the modem, the default wifi SSID name seen on the modems sticker is not seen on a laptop or wireless device?
- Rainer91Jan 06, 2022TutorI’ll try to get my hands on one of those cables. When I do the reset or power on off it still doesn’t show up on any device. It powers on and after a few seconds goes back to the lights blinking.
- FURRYe38Jan 06, 2022Guru - Experienced User
I would review the online user manual to see what the LED indication means. Possible there maybe a problem with the modem...
