SWHerbert
Jul 03, 2018Follower
N600 C3700 Modem Router all lights blinking in sync
Hi all, a bad rain storm here caused my WiFi to go out, looked at the lights on my router and all were flashing in sync, power is amber and all others in green; very abrupt flashing, like 2 flashes p...
DarrenM
Jul 09, 2018Sr. NETGEAR Moderator
Try to hold the reset button for 30 seconds if not the modem could be bricked you will either have to contact support if the modem is still under warranty or replace the unit.
DarrenM
