Bouchnet
Jul 28, 2019Aspirant
N600 C3700 Modem/Router settings in Router not routing via OpenDns network per configuration
The dns settings in the router have been set to: 208.67.222.222 208.67.220.220 208.67.222.220 Problem is that any device useing router should be routed through these settings but it’s not w...
- Jul 29, 2019
How are you determinine that your connected devices are not being routed thru these DNS addresses?
All DNS seen on the LAN side will have a 192.168.0.1 address probably and thus will be routed thru the C3700 and the DNS set there...
Bouchnet
Aug 01, 2019Aspirant
Solved. Using the Genie App, I setup Parental Controls option and from there it connected to to my OpenDns account. Within the app I rebooted the Router and now all my devices are using OpenDns. Thanks for your help.
Aug 02, 2019Guru - Experienced User
Enjoy. :smileywink:
