RONC44
May 05, 2017Aspirant
N600 C3700 Wifi Speeds Slow
any updates to solving slow speeds. Checked down load speed using router ethernet port 60mps. using wireless 5 mbs. cable provider says the router is the problem.
- May 13, 2017
Darin thanks for your reply. I reset wireless router back to factory settings. I reset the settings to my preferred ones. Presto every thing works.
