newstudent
Jun 03, 2019Aspirant
N600 C3700 Wifi Speeds Slow
I have read on this site and online that this is a known issue and yet Netgear is not responding unless you are willing to pay for them to manually go in and adjust the settings! This is what I was t...
Jun 03, 2019Guru - Experienced User
What are the wired speed results with a wired PC?
Some wifi devices don't support fast wireless speed testing. Check with your devices Mfr support site to see what your devices support.
What are your current wifi settings?
newstudent wrote:I have read on this site and online that this is a known issue and yet Netgear is not responding unless you are willing to pay for them to manually go in and adjust the settings! This is what I was told last night because my 90 day support is over! I have Xfinity 150mbps I get 11mbps on 2.4 and 21mbps on 5! Xfinity has checked and said the issue is with the modem, which I might add is rated to 300mbps! PLease make a video to show your customers how to make the adjustments instead of trying to hold us hostage to fix your product. The attached screen shot was of no help.
newstudent
I sent a few screen shots of what you are looking for I think 8-)
- FURRYe38Jun 04, 2019Guru - Experienced User
I don't see any pictures attached to the posts here.
- newstudentJun 04, 2019AspirantThe pictures are attached in message 3
Any other feature settings under Advanced Tab/Advanced Settings/Advanced wireless? If you see WMM enable, this needs to be enabled. I don't know if you'll see beamforming or smart connect. This modem maybe pre release to those features.
