newstudent
Jun 03, 2019Aspirant
N600 C3700 Wifi Speeds Slow
I have read on this site and online that this is a known issue and yet Netgear is not responding unless you are willing to pay for them to manually go in and adjust the settings! This is what I was t...
newstudent
I sent a few screen shots of what you are looking for I think 8-)
Jun 04, 2019Guru - Experienced User
I don't see any pictures attached to the posts here.
- newstudentJun 04, 2019AspirantThe pictures are attached in message 3
- FURRYe38Jun 04, 2019Guru - Experienced User
Any other feature settings under Advanced Tab/Advanced Settings/Advanced wireless? If you see WMM enable, this needs to be enabled. I don't know if you'll see beamforming or smart connect. This modem maybe pre release to those features.
I did a factory reset, I took another screen shot of the settings you requested I check
