steinste
Apr 24, 2017Aspirant
N600 cable modem router
I Just left Comcast and now have an ethernet jack that provides internet. Is there a way to set the n600 to use Ethernet as the internet source instead of the cable rf signal?
steinste
C3700, it's a byo router situation.
I had a WGT624v2 but i updated the latest firmware which bricked it.
TheEther
Apr 24, 2017Guru
Unfortunately, the C3700 doesn't have an Ethernet WAN port, so you won't be able to use it as a router. You'll need to get a new router. You can use the C3700 as an Access Point to expand your Wi-Fi coverage. But you may simply be better off selling it.
