skitter12
Feb 26, 2022Aspirant
N600 Wi-Fi DOCSIS 3.0 Cable Modem Router (C3700) PASSWORD
My son is trying to log in on his laptop. He is suing the UN and password and still getting error that they do not match. We have confirmed caps and sequence and network are all correct? Any re...
skitter12
Of course that won't connect to the wifi extender, this does NOT need to be this difficult....4 hours later.
skitter12
So that coonect to the same log in page for to connect via phone that doesn't work.
Literally you can't get there from here, catch22!!!!!!!!!!!!!!!!
- plemansFeb 27, 2022Guru - Experienced User
so you'vee gotten it more complicated.
You have a router and an extender.
1. what extender do you have?
2. what page are you trying to connect to? (a screen snip helps)
3. what error is it giving you? (again, take a screen snip)
4. are you trying to connect to the wifi? trying to connect to the gui? details are key
5. if you're concerned the extender is causing issues for you logging in (if it does have different credentials) power it off and try
6. you can always hardwire into the router to access it. Then you don't have to worry about the wifi login/password. Just the gui info.
