Cluking
Jul 28, 2018Follower
N600 WiFi Cable Modem Router Password Issues
Hi. Bought my N6000 Cable Modem Router, Model No. C3700, about two months ago and got it installed and it worked fine. Then about three weeks ago I started having issues logging in to wifi. Ethernet works fine, and the password isn't incorrect, because if I unplug the router and plug it back in the password works fine for a few hours, until it stops working again and I have to unplug it again. I was hoping someone could shed some light on my problem here. Thanks for the help!
1 Reply
- DarrenMSr. NETGEAR Moderator
Have you tried changing the wireless password and telling your devices to forget the network then connect to the new password? Or you may even want to try and change the SSID of the network.
DarrenM
