MartinaG
Jan 17, 2018Aspirant
N600 wifi router modem router
MartinaG
Jan 19, 2018Aspirant
I DId follow lo the steps as indicated that is the reason why I posted in this blog for help. Thanks I will look for help someplace else
antinode
Jan 19, 2018Guru
> I DId follow lo the steps as indicated [...]
I don't see the steps which you took. All I see is:
Ring-c08dbc
Security-non-enabled
and a bunch of "Access Control" reports. I don't know what
"Security-non-enabled" means, but my guess is this:
> [...] Either you need to tell the
> Ring gizmo which wireless network credentials to use, or else you need
> to go through a WPS set-up procedure.
I see no signs that you have done anything to let this Ring gizmo
join your wireless network. Not blocking it with "Access Control" stuff
is not enough.
> [...] I will look for help someplace else
No matter where you go, you may need to supply some useful
information, and/or answer some basic questions.
