leoverlord
Oct 17, 2017Aspirant
N600/C3700 - Modem/Router - Wont go into Router Mode
My n600 c3700 modem/router stays in bridge mode only. When i go into the netgear genie, using the standard ip 192.168.100.1 I'm giving very limited options... One under advanced in router mode, and i...
DarrenM
Oct 19, 2017Sr. NETGEAR Moderator
Have you tried to unplug the cable cord from the modem before doing this they after the reboot connect the cable cord again.
DarrenM
- leoverlordOct 20, 2017Aspirant
Yeahup I've tried on and off, rebooting the modem, factory reseting it through the genie and on the modem... nothing, it will not go into router mode
- DarrenMOct 20, 2017Sr. NETGEAR Moderator
It could be a issue on the ISP side if they have the coding wrong for the modem it could have it locked as only a modem.
DarrenM
