alopez18
Jun 01, 2020Aspirant
NAT Type 3
Hopefully anyone here can help me. I called them 4 times and nobody knew what i was talking about. Got hung up on twice. I really hope i can get the help i need from the community. Anyways, so i have...
Jun 07, 2020Guru - Experienced User
Try setting NAT FIlter to OPEN. Look for this under Advanced Settings/WAN setup
- alopez18Jun 08, 2020AspirantThere is no such option in WAN setup or anywhere else
- FURRYe38Jun 08, 2020Guru - Experienced User
Have you hard powered OFF the PS consoles, powered OFF the modem for 1 minute then back on?
Then turn on 1 PS and check NAT status...
If this doesn't work, hard power OFF the PS console, factory reset the modem and setup from scratch with a wired PC.
uPnP should be enabled and no PF configurations or DMZ should be enabled.
